Marsh & McLennan Agency LLC
Last activity: 20 Sep 2018 11:33 EDT
Edge Browser Suppport
Guys,
Does PRPC 7.1.9 version supports Edge Browser ?
I have recently tried to hit our application url in edge and it redirects to IE 11 browser.
Prasanna
FR
No redirection to IE 11 for me. Working correctly with Pega 7.1.7 as well
Do we need to make any changes to Edge browser before we start using our application ?
Gabe Isko neeraj soni Ravi Kumar Pisupati Marc Cheong Armin Schmid and 1 More
Hi Prasanna,
Yes 7.1.9 works in Edge browser.
Tashika
Tashika,
As per support guide 7.1.x versions only support IE 11 and not Edge browser but you have mentioned Edge browser is supported.
Sorry for the misunderstanding.
7.1.9 works fine in Edge but not supported. In Pega 7.2.1 and later, both IE11 and the Edge browser are supported.
Vodafone
The product has not been tested in Edge browser, as when Pega 7.1.9 release - Edge browser was not available. Pega platform support guide hasn't mentioned about Edge browser support.
Pega 7.1.9 will work on Edge browser but not officially mentioned in any documentation.
On release of Pega 7.2.1 Edge browser is available and officially noted in Pega platform guide.
Naveen
Adaps
Below link might help you
https://collaborate.pega.com/question/does-pega-v721-support-microsoft-edge-browser
Thanks guys.
My issue is narrowed down, I have two node url's and a load balancer url. The redirection to IE 11 happens only when I use load balancer url and with node url's im able to login without any issues in Edge as well.
Anyone experienced this particular scenario.
Then there must be some setting in load balancer that is causing the redirection. You can check with your respective team.
