    capgemini
Last activity: 8 Aug 2024 17:02 EDT
Dynamically change the color based on the two property match results
i have current information in the case, i am fetching the information with external after that get the data like this
Attribute Name Current Information External API information
Name Eswar Eswar Reddy DOB 22/05/1999 22/05/1999 Age 25 25
based above result i want to change the color dynamically in the ui, which layout i want take, and how can change dynamically matched color green not matched i want to display yellow, how can i implement above use case, Could you please help some one(11 properties results i want match)
