TechM
Last activity: 27 Dec 2016 5:17 EST
To display message over Hover
The requirement is to show some message (or information) when the user points the mouse over the name of the product .This product is displayed
in the repeating grid list.
Credera
J.P. Morgan Services India PVT Ltd
Hi Vandana,
Please use "smart tip" functionality.
Configure it on the action set by using mouse hover event with "smart tip" action, in that we can create our own custom message which we want to display.
Neha
Hi Vandana,
This can be achieved in multiple ways depending on your exact requirement.
If it is only a plain message or a very short text. You can either use tooltip or Smart Tip as suggested.
If the content on hover is more and include some other content than plain text, then Smart Info could be used as UI event.
Let us know if this helps.
TechM
Thanks rawap.But I have tried with Smart tip but it didnt worked on the list.The page group is defined in work class and then
page list is defined in the page group class.We have some items under one page group category and each page group has 5 list
of items. Requirement is to display message on hover of one particular item under a particular list (which is there in a group).
Blue Rose Technologies GmbH
BE
You can use use tooltip or Smart Tip to achieve your requirement.
Thanks.
Hi
Can you please provide a screenshot for your requirement. I think your requirement of showing display message on hover of one particular item under a particular list can be done via smarttip or tooltip feature. If it is not happening that we need to understand how you did the design and where exactly the issue is. Having screenshot will help us here ! Thank you
Credera
You can use
1. Tool tip if it is any control
2. Local action - Overlay option
3. Smart Tip or Smart Label
Credera
Hi Vandana,
Did the above 3 solution fit your requirement?
You can use
