Disable "is not a valid date value" validation
Hi everyone,
I want to disable invaid date of pega.
How can I set it? I attach image below.
Thank you!
Hi everyone,
Thank you!
By OOTB, the Date and DateTime control will display the error "xxxxxx is not a valid date value" when the date format entered in the field at runtime is not a valid one specified for the control.
If you want to disable the error, enter the correct value or change/customize the control as per your requirement.
well, it's endeed invalid date.
What do you mean by "disable invalid date"?
basically, you either need to fix the value or to change a property type
yaahh, but I want to use Datetime property type.
I want to use my defination validate.
I dont want to display Pega's validate message. Such as ".... invalid date" ....
Thank you for helpful!
