Evonsys
Last activity: 18 Jan 2024 6:34 EST
Dirty check not triggered on cancel, even after values on ui are changed pega 8.7.4
we have a simple UI with a Radio button and dropdowns which are conditionally visible based on radio button
we have configured refresh on change for radio button so that dropdown values are fetched from data page source
if user tries to click on cancel , expectation is dirty check or unsaved changes pop up should come but it is not happening
can you please share what is the expected behavior here?
PS: read almost all posts related to diry check didnt find appropriate answer.
Also this issue is happening only when refresh this section is configured on the control, most of the use cases needs this as UI elements or data sources are conditionally loaded.
Prudhvi.
***Edited by Moderator Rupashree to add Capability tags***
