Difference between SysAdm4, SysArch4, and ProArch4
I believe SysAdm4 is the most well known access role with the full capabilities. There are two other access roles - SysArch4 and ProArch4. SysArch4 is for Business Architect and System Architect with less capabilities than SysAdm4 while ProArch4 is focused on process creation with least capabilities (https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#security/access-groups-and-roles/sec-std-access-roles-ref.htm#Standard_access_roles).
I understand high level description as above, but are there any relations with portal (Developer and Express)? For example, SysArch4 and ProArch4 are designed for Express only and not really for Designer Studio? Where exactly are these two access role given guys supposed to work on build?
