Tata Consultancy Services
Last activity: 3 Sep 2018 4:15 EDT
Difference between Primary. vs TOP.
Hi All
How to decide when to choose Primary. And TOP. In activity.
  Likes (1)
Marie Jager  -
Areteans
Hi Ramesh,
It depends on your requirement completely.
Lets say, you have main flow and you are calling an activity A in it and again activity B is being called from A.
If you want to map some properties on the page where B activity is executing, then we will select Primary.
And If you want to map some properties on the page where main flow is executing, then we will select Top (refers to pyWorkPage mostly in flow case execution).
Hi Ramesh,
Please refer the link for more info: https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm#definitions/p/primarypage.htm
Divya Sri Padarthy
RAJU TEKU Mohamed BOUANENE Swetha Ramaiah Praveenkumar Rajavel
Primary always refers to the page context under which your current rule is being executed. When the primary page is an embedded page ( MyTopLevelPage.MyEmbbeddedPage), then TOP always refers to the top level page of your current page context (in this case MyTopLevelPage). If there are multiple levels, it always refers to the TOP most.
Marie Jager Praveenkumar Rajavel
HI,
primary: In the context of an activity, refers to the primary page of that activity.
top :In the context of an embedded page, identifies the top-level page to which the current embedded page belongs.
Somenath Karmakar
CollabPartnerz
Top always refer to the toplevel page
but where as Primary refers to the in which class your running
Thanks All
Sai Krishna Swaroop Vinukonda
wc, please revert back to us if you need more clarification.
