Delimiter not recognised by Pega
On the System Architect Essentials Course, lesson 19 you have to import the provided .csv file with Service Providers. (attached as a .txt file because .csv's cannot be uploaded)
However, when I try to import the file provided it says only one field is in the file. In other words, the separator (delimiter) "," is not recognized by the system.
Should I create a rule stating that a comma separated list is separated by, surprise, a comma?
Have to say, I do not find the course very helpful as you have to be a full fledged application manager with major IT skills to be able to install and run Pega before you can even start training in its basic functionality as a business analyst.
Disappointed.
***Moderator Edit-Vidyaranjan: Moved from PSC to Academy***
