Morgan Stanley
Last activity: 14 Nov 2019 9:13 EST
Decision Table error: Goal seek requires missing input property
While executing a decision table using ObtainValue function i'm getting the below erro
FR
Can we have few screen shots. Why do you need a function for your Decision table.
Tata Consultancy Services
Can you try below approach?
@(Pega-RULES:DecisionTable).ObtainValue(tools, "Page on which your Decision table execute", "Decision Table")
Morgan Stanley
I in fact have used the same function ObtainValue as you suggeted above..
I have used the function in a Data transform to get the value of a property.. But when i execute the decision table its throwing the error "Goal seek requires missing input property"
vasu narne Kamil Janeczek
Blue Rose Technologies
Step page is missing and it is unable find the input values. Make sure to pass step page.
IAG
Try this :
@(Pega-RULES:DecisionTable).ObtainValue(tools, "Page on which your Decision table execute", "Decision Table", true)
This fixed the issue for me as the property used in DT was not set in the page. The last param in the function is equivalent to "AllowMissingProperties"
Sudipta Biswas Guilherme Dumas Peres Ratna Govad
Commonwealth Bank of Australia
Before calling the Obtain values function set Param.AllowMissingProperties = true ( While called from Data transform )
OR
If you are calling the decision table from Activity then there is a check box in the parameter to allow missing property, Please check that
Sudipta Biswas Pothuraju Goli
I was having same issue as described in the original thread. Once I added the "true" param, to allow for missing values, the Obtain Value errors disappeared.
