DCO Compatibility Tool
We are building a new application and have created our Case type and other rules refer for the application.
We are now trying to use DCO in the following and so I ran DCO Compatibility Tool.
Designer Studio--> Application--> Tools--> Check DCO Compatibility.
The Following tool ran and give us the warning :
"This application has work class names that are too long by 3. Please consider refactoring them."
Need to understand what is meant for and what is the impact of this Warning.
Our Case Type Name Max Length is 12.
Gaurav
you need to rename work class name using refactoring as below
Use the Rename a Class wizard to refactor the class structure (Designer studio > System > Tools > Refactor Rules > Rename a Class ..
reduce 3 letter
