DB Server configuration for Distribution Test
We're using both of dist.tests and campaign runs together on Prod environment. We want to learn possibilities of changing db connection setting for only dist.tests on context.xml file or strategy's configuration. Because we want to reduce db system load from prod environment. If we can separate the db layer for dist tests and campaing runs, we will gain performance for db side.
