Ncs Pte Ltd
SG
Last activity: 21 May 2018 16:54 EDT
In DateTime control, minutes need to show as 10 min interval.
Hi Team,
Please advice on below. Is there any customization code for this?. Attached screenshot is the current OOTB behavior.
We have requirement to show minutes as 10 min interval in DateTime Control. With current OOTB feature it's showing 1 to 59 and this makes the drop-down list extremely long.
Thanks, Dinesh G.
By default, the time picker displays minutes from 0 through 59. To restrict the time selections that are available to users, you can configure your application to display intervals of minutes on time controls, instead. Select the Allow time to be displayed in the interval of minutes option and click the corresponding number of minutes: 5, 10, 15, 20, or 30. At run time, the times available for selection are based on this setting. For example, if you set intervals of 15 minutes, a user can select 9:00 AM, 9:15 AM, 9:30 AM, or 9:45 AM in the application.
Select Datetime control , presentation tab , select the checbox Intervals in an hour and select the desired interval.
