Bluerose Technologies
Posted: Apr 4, 2018
Last activity: Apr 4, 2018
Last activity: 4 Apr 2018 21:58 EDT
Problem encountered when getting a database connection:code:20 SQLState:61000 Message:The network
Adapter could not establish the connection
Test connectivity is failing due to the above error.
could you please help on this?
I suggest that you review the database details configured in the database rule.
Verify whether you are able to connect to database using the same details outside pega using sql developer.
Refer the below link for more details on the error
