Last activity: 5 Jul 2019 3:18 EDT
Data Types - Import and Export - Is this functionality still supported at Pega Platform 7.3.1?
The options to import and export data from and to Excel do not show as actions at 7.3.1 off the records menu
Is this deliberate and is this functionality supported in another way?
The functionality is supported but an upgrade that envisages the use of Excel to port data between the old and new environments (across Pega Platform version) is not supported. This is because the Data Type exists and yet no data exists in the underlying tables. The import/export options are visible when data exists.
The adopted solution at the customer is to port the data using Oracle export/import.
Citicorp Services India Private Limited
Import and export options is not present under actions menu. However import and export options are still present in the data designer for a data type. Please find the attached screen shot.
Gowrishankar.
LTIMindtree
Export functionality is not working in Data type.
We delgated the data type rule and is available for manager and user both, Administrator is able to export the file but user is not able to export.
some privilege issue alert is coming, Is there any OOTB specific privilege given to manager to access the export functionality?
LTIMindtree
LTIMindtree
Cognizant technology Solutons
This might help
