IT
JP
Last activity: 11 Nov 2020 6:29 EST
Data page parameter reference facing error
Hi
I need to refer parameter in data page, but I face the error attached.
May I have advice?
Does the D_ListSample22 Data Page have parameters set on the Parameter tab of the rule form? Are there any other versions of this Data Page?
IT
JP
Hi, CarissaW_GCS
Thank you for your reply.
Parameter has already been set in parameter tab, and no more version. just one...
I don't know why it does not work.
Best regards,
Run Tracer when trying to save the Data Transform and include the DB Query event type in the trace. Then check the Rule-Obj-Model Validate steps in the trace to see the pzInsKey for the Data Page that was used so you can compare that with the rule you opened.
I was testing on an 8.4.3 system and I can see a DB Query execute at step 5 of Rule-Obj-Model Validate. I was able to see the pzInsKey in the query and compare that with the rule I was expecting.
IT
JP
Hi, all
It is not still working.... any advice?
The DB I would like to access is new local storage, so key is not pzInsKey...
The Data Page rule will still have a pzInsKey.
- What Pega version are you using?
- What did you see in the trace for the Rule-Obj-Model Validate step 5 where it opens the Data Page rule? Then compare the pzInsKey of the Data Page rule from the Trace with the value you see in the Data Page rule (select Actions > View XML on the rule form).
Updated: 9 Nov 2020 12:00 EST
P3Fusion
@YukiS888 As mentioned above check datapage has parameter & Mention the DataPage under the Pages&classes tab of DataTransform.
IT
JP
I've already set the parameter under Page&Classes though..
Please use Following expression if your Data page type is Page
ForecastFamilyValue = D_ForecastFamily[BigC:Param.BigC,Location:Param.Location].ForecastFamily
Pooja
