Standard Chartered Global Business Services
Customize the control and text sizes of OpenSpan
I recently upgraded to a new system, which has the Windows Display setting 'Make text and other items larger or smaller' been set to 'Medium - 125%' as the default.
However, with this setting, the automations appear cluttered - with the size of the controls being oversized and overlapped with each other and becomes hard to read and debug. When I change the setting 'Make text and other items larger or smaller' been set to 'Smaller - 100%', then it appears to be normal as with my previous system (that has 'Smaller - 100%' as default).
My problem is with changing to 100%, then reduces the size of my other windows applications and it becomes hard to read. Is there a way to customize (in my case to reduce) the size of the controls/text size for OpenSpan only? Zoom in/out does not help me.
I also tried changing the 'Fonts and Colors' setting in the IDE, but it has no effect. Any suggestions?
