CSV format string from a Pagelist property values
I have a requirement to capture list of values of a property which is pagelist and show it in string in a comma separated format in a hierarchy of embedded page lists.
For Ex: I have a property PropertyN in PageListC in the hierarchy pyWorkPage.Page.PageListA().PageListB().PageListC()
PropertyN has values as follows --> pyWorkPage.Page.PageListA(1).PageListB(1).PageListC(1) - P1
pyWorkPage.Page.PageListA(1).PageListB(1).PageListC(2) - P2
pyWorkPage.Page.PageListA(1).PageListB(1).PageListC(3) -P3
and
pyWorkPage.Page.PageListA(1).PageListB(2).PageListC(1) - P1
pyWorkPage.Page.PageListA(1).PageListB(2).PageListC(2) - P4
pyWorkPage.Page.PageListA(1).PageListB(2).PageListC(3) - P5
I have to show a string property PropertyNConcetanted at PageListB level which shows as follows- pyWorkPage.Page.PageListA(1).PageListB(1).PropertyNConcetanted --> P1,P2,P3
Also, pyWorkPage.Page.PageListA(1).PageListB(2).PropertyNConcetanted --> P1,P4,P5
and I have to show a string property PropertyNConcetantedTop at PageListA level which shows as pyWorkPage.Page.PageListA(1).PropertyNConcetantedTop - It should have a property that holds csv values as --> P1,P2,P3,P4,P5 without duplicates.
and
Can you please suggest the best approach?
Hi NagaMrudulam,
You can try using 'pxStringCSVFromPageList' OOTB function to get CSV format string from the pagelist.
eg: @pxDataManipulate.pxStringCSVFromPageList(pyWorkPage.Page.PageListA(1).PageListB(1).PageListC,".PropertyN") Result - P1,P2,P3
@pxDataManipulate.pxStringCSVFromPageList(pyWorkPage.Page.PageListA(1).PageListB(2).PageListC,".PropertyN") Result - P1,P4,P5
Hope it helps.
Thanks.
