CSSA 7.21 Ruleresolution Exercise. Benifits Enrollment uses Framework
6. Create a new Benefits Enrollment case and follow the steps above to confirm the context of the
EmployeeInformation section record is in the TGB-HRApps-Work class and the HRApps:01-01-
02 ruleset.
Instead is uses:
02 ruleset.
Instead is uses:
Hi Marius,
Did you remember to mark that one withdrawn as well ? (if you view detailed steps it has you mark 3 versions as withdrawn Onboarding, Employee Evaluation and Benefits Enrollment.)
With that said, I am having an issue where it is using a version in the data class (TGB-HRApps-Data-Employee) ???
