Could not initialize services of type [StreamServer]
Hi All
We are trying to perform an out-of-place upgrade from 6.3 to 8.5.1
We followed below steps:
1. Install clean 8.5.1
2. Copy pega_rules and pega_data schema from 6.3 and run upgrade.sh
3. Point websphere to upgraded schemas in step 2.
Along with above major steps, there are other minor steps like cleanup, adding privileges, etc.
We are facing below error on startup. We have also updated jdk config to not inlcude 'Stream' node for -DNodeType. Start up is still failing with NullPointerException. Does anyone know how to solve this?
Hi All
2021-03-15 11:45:11,701 [ wokvl0-sam-upgrade] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Created provisional node: "wokvl0-sam-upgrade pega 2021-03-15 11:45:00.885 GMT", []
2021-03-15 11:45:12,149 [ wokvl0-sam-upgrade] [ STANDARD] [ ] [ ] ( prpc.service.ServiceManager) ERROR - Could not initialize services of type [StreamServer]
2021-03-15 11:45:12,191 [ wokvl0-sam-upgrade] [ STANDARD] [ ] [ ] ( internal.mgmt.PREnvironment) ERROR - java.lang.NullPointerException
2021-03-15 11:45:12,192 [ wokvl0-sam-upgrade] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: wokvl0-sam-upgrade
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:427) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:2176) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:683) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:180) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:152) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.doStartup(EngineBean.java:127) ~[prprivate-session.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90) ~[?:1.8.0]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) ~[?:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:508) ~[?:1.8.0]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:388) ~[prbootstrap.jar:8.5.1-208]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:430) ~[prbootstrap.jar:8.5.1-208]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:225) ~[prbootstrap-api.jar:8.5.1-208]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:247) ~[prbootstrap-api.jar:8.5.1-208]
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.doStartup(EngineBeanBoot.java:135) ~[prbeans.jar:8.5.1-208]
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.doStartup(Unknown Source) ~[prbeans.jar:8.5.1-208]
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:210) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.servlet.AbstractLifeCycleListener._contextInitialized_privact(AbstractLifeCycleListener.java:145) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.servlet.AbstractLifeCycleListener.contextInitialized(AbstractLifeCycleListener.java:76) ~[prwebj2ee.jar:?]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:274) ~[prbootstrap-api.jar:8.5.1-208]
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:92) ~[prbootstrap-api.jar:8.5.1-208]
at com.ibm.ws.webcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:1837) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:443) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:88) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:171) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:904) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.addWebApplication(WSWebContainer.java:789) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.component.WebContainerImpl.install(WebContainerImpl.java:427) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.component.WebContainerImpl.start(WebContainerImpl.java:719) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1249) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedApplicationImpl.java:1590) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:707) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:1161) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:801) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.ApplicationMgrImpl$5.run(ApplicationMgrImpl.java:2325) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5446) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5662) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:2330) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:436) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.CompositionUnitImpl.start(CompositionUnitImpl.java:123) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:379) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.access$500(CompositionUnitMgrImpl.java:127) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl$CUInitializer.run(CompositionUnitMgrImpl.java:985) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.wsspi.runtime.component.WsComponentImpl$_AsynchInitializer.run(WsComponentImpl.java:524) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1909) ~[com.ibm.ws.runtime.jar:?]
Caused by: java.lang.NullPointerException
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.validateStreamAPI(StreamServiceInitializationTask.java:95) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.access$100(StreamServiceInitializationTask.java:32) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:82) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:291) ~[d-node.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1388) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1131) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:938) ~[prprivate-session.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:284) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:146) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.initStreamServerServiceAndValidate(StreamServiceInitializationTask.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.runTask(StreamServiceInitializationTask.java:51) ~[d-node.jar:?]
at com.pega.pegarules.session.internal.async.startup.StartupTaskUtil.runTask(StartupTaskUtil.java:89) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:1034) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:407) ~[prprivate-session.jar:?]
... 52 more
