Blue Rose Technologies
BE
Last activity: 1 Nov 2024 8:35 EDT
CORS error when trying to run a pega webembed from a custom HTML file from browser
We have created an application on constellation in pega labs.
created a web embed to create a case.
created a html page with this web embed code and then placed it in our local machine tomcat.(to launch it as http://localhost:8080/docs/WebEmbedTest_XYZ.html)
when the html is run from the browser then it asks for credentials and successfully showing the pega case.
which means web embed is working fine with basic auth.
https://XYZ.pegalabs.io/prweb/
Problem scenario :
1. we have created a authentication service /prweb/PRWebLDAP1
2.generated the web embed code again and updated the pega URL with this URL created in step1.
https://XYZ.pegalabs.io/prweb/PRWebLDAP1/
3. Now when we try to load the HTML page in the browser then it shows
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://XYZ.pegalabs.io/prweb/PRWebLDAP1/PRRestService/c11nsvc/v1/config. (Reason: CORS request did not succeed)
