Correct deploy of Pega Applications
I did this application stack:
My objective is to see how the sample applications works together, in a CRM and CRM For Communications mode. Connecting it with a Product Catalog and using the sample data in each one of the applications.
How should I install and implement this applications to make it work for demo purpose? Is there any order to follow?
I tried to follow the installation and implementation guides following an order - from the bottom to the top - in the schema, but I'm facing a lot of problems since I'm not able to distinguish between what I should follow or not in the implementation guides.
