Amazon
Last activity: 19 Jul 2018 15:53 EDT
Control Not Transferred To Right Automation From IE 11
Hi Guys,
Design:
I have a robotic solution which had two projects in it.
1. A Pega application interrogated as a web application using IE 11.
2. A windows based standalone application. This is the startup project with all the references and other project dependencies added properly.
Problem:
I have configured interaction framework in such a way that if I pass a value from pega screen the interaction activity should start in Pega app and captured in windows app (the interaction is working properly without errors)
The automation runs fine and gets the desired result from windows app when I run it from Robotic Studio. But when I run it through Runtime the control stays back in IE itself.
Note: I had a sendkeys activity on windows app but the Runtime is executing that command on IE 11. Please see the screen shots attached.
Any help on this is really appreciated!!
Thanks & regards,
Prasanna
***Edited by Moderator Marissa to add SR Details***
