Wells Fargo & Company
Last activity: 14 Oct 2019 2:48 EDT
Configure Multiple instances prpc - websphere - (vertical stack - single server)
We currently have multiple instances horizontally configured in a websphere cluster for prpc 7.4. We have added substantial more memory on our servers and as our cpu has low utilization we wanted to try run multiple instances on a single server to better make use of the available cpu.(ie vertical stack the instances) Initially trying to configure this - only the 1st instance starts successfully. I am looking if there is a document on what components should be configured dynamically to get these instances to start up correctly without conflict (ie port# should be different for each instance - Log file path should be different for each instance, etc... ) has anyone done this and how did they configure a websphere cluster to accommodate vertical and horizontal stacking of jvm's ? Thanks for any help
