CTS
Last activity: 4 Feb 2022 6:17 EST
com.pega.dsm.dnode.api.DNodeException: Could not perform database dataset operation on Work pool class
Hi All, When executing Data Flow getting the following exception in one of the work pool classes. The similar Data Flow works in another work pool class in the same application.
The application has two work pools. Only one work pool class is having the following issue.
com.pega.dsm.dnode.api.DNodeException: Could not perform database dataset operation on ZZZ-XXXX-YYY-Work
java.lang.IllegalStateException: com.pega.dsm.dnode.api.DNodeException: Could not perform database dataset operation on ZZZ-XXXX-YYY-Work at com.pega.dsm.dnode.impl.stream.DataObservableImpl$ObservableIterator.hasNext(DataObservableImpl.java:198) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$ObservableIterator.next(DataObservableImpl.java:229) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.first(DataObservableImpl.java:154) at com.pega.dsm.dnode.api.dataflow.DataFlow.getNumberOfExpectedRecords(DataFlow.java:795) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.createFor(PartitionCreator.java:78) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.access$000(PartitionCreator.java:45) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator$1.run(PartitionCreator.java:62) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator$1.run(PartitionCreator.java:59) at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:291) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1380) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1123) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:284) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:146) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.createFor(PartitionCreator.java:59) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.RunInitializationTask.preparePartitions(RunInitializationTask.java:204) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.RunInitializationTask.asyncExecution(RunInitializationTask.java:130) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask$1.run(AsyncAssignedTask.java:69) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask$1.run(AsyncAssignedTask.java:58) at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:301) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:146) at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask.lambda$tryToExecuteInLock$0(AsyncAssignedTask.java:58) at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:108) at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:41) at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:77) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:59) at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:56) at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:124) Caused by: com.pega.dsm.dnode.api.DNodeException: Could not perform database dataset operation on ZZZ-XXXX-YYY-Work at com.pega.dsm.dnode.impl.dataset.database.DatabaseOperationsUtil.lambda$observableForDatabaseOperation$0(DatabaseOperationsUtil.java:78) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$ObservableIterator.(DataObservableImpl.java:191) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.iterator(DataObservableImpl.java:149) ... 31 more Caused by: java.lang.NullPointerException at java.base/java.util.TreeMap.getEntry(TreeMap.java:345) at java.base/java.util.TreeMap.get(TreeMap.java:277) at com.pega.pegarules.data.internal.store.TableInformationImpl.getColumn(TableInformationImpl.java:309) at com.pega.pegarules.data.internal.sqlapi.resolve.NativeSQLAPIResolver.setColumnTypeForField(NativeSQLAPIResolver.java:395) at com.pega.pegarules.data.internal.sqlapi.resolve.NativeSQLAPIResolver.resolveFilters(NativeSQLAPIResolver.java:757) at com.pega.pegarules.data.internal.sqlapi.resolve.NativeSQLAPIResolver.resolve(NativeSQLAPIResolver.java:139) at com.pega.dsm.dnode.util.NativeSQLBatchReader.(NativeSQLBatchReader.java:94) at com.pega.dsm.dnode.util.NativeSQLBatchReader.(NativeSQLBatchReader.java:98) at com.pega.dsm.dnode.impl.dataset.database.DatabaseGetNumberOfRecordsOperation$1.executeExposedLogic(DatabaseGetNumberOfRecordsOperation.java:76) at com.pega.dsm.dnode.impl.dataset.database.DatabaseOperationsUtil.lambda$observableForDatabaseOperation$0(DatabaseOperationsUtil.java:73) ... 35 more
