On click of close on Modal Dialog Lock is getting released
I have a repeating grid layout To edit the contents of a given row i have used a button to Open Local Action and Disabled the Work Processing option , On Clicking Close Of the Modal Dialog the lock is getting released and it is unable to advance the flow .
I have Traced it and Lock is released in SubmitModalFlowAction Activity.
Error :You lost the ability to make this change because a change elsewhere has taken precedence over the change you made here. Lock is required .
Currently using Pega 7.1.5 , If there is any hotfix already existing for this issue please provide the number.
***Updated by Moderator: Lochan. Removed user added helpme and FAQ tags. Apologies for confusion, shouldn't have been an end-user option; updated categories***
