On click of autocomplete property label, the control automaticaly goes back to the top of the page(On another autocomplete property)
We have a screen which comprises of 4 sections.An autocomplete property is in the 4th section and on click of the label of that property the control goes to the autocomplete property of 1st section. Both the properties are Ref properties. Please let me know if any suggestions on how to avoid this or make the label non clickable.
Thanks in advance.
***Updated by moderator: Lochan to add SR Exists Group Tag***
Hi Shashi,
We have see similar use cases in the past however to avoid the issue the only way is to use different properties being referred however this would be against the concept of reusabilty.
As issue is observed on PRPC 7.2.1 and considered as an Enhancement request (FDBK-18152). You need to work with your Account Executive to check when this could be incorporated in future release.
Shanthini Charles
