bitsinglass
Last activity: 10 Feb 2026 12:54 EST
Circumstance specialization in Pega LSA mission
Example cited for circumstance is as below.
"For instance, consider a loan approval application that offers different interest rates based on the customer's credit score. Instead of creating separate Rules for each credit score range, you can use circumstance specialization to create variations of the base Rule.
Create a base Rule that calculates the interest rate for a loan. Circumstance the base rule by using the property CreditScore. Create specialized Rules for different credit score ranges, such as:
- Circumstance 1: If 'CreditScore' is between 300 and 579, set the interest rate to 10%.
- Circumstance 2: If 'CreditScore' is between 580 and 669, set the interest rate to 8%.
- Circumstance 3: If CreditScore is between 670 and 739, set the interest rate to 6%. "
Is this a valid example for circumstance ? Above requirement can be easily implement using decision table, right?
Please advise.
