Change RunTime Version - Pega Studio
Currently I am using Pega Studio 8.0.2012 version. When i deploy the code in Runtime 8.0.1105 i am getting error due to lower version. How can i set the runtime version in Pega Studio while development.
Hi
There is no option setting the Runtime version in Studio. Generally we recommend to use same version of Runtime as Studio to avoid runtime issues. Hence, suggesting you to install same version of Runtime and deploy the solution.
Hope this helps you.
Srini
