CIBC
Last activity: 4 Dec 2018 7:49 EST
Certified Robotics System Architect (CRSA) exam material
I recently attended the exam, but couldn't clear the exam because of the following reasons.
1. There is a huge gap in between course material provided in PDN and the actual exam
2. I thought taking all the courses of robotics would help me to clear the exam, but this is not at all sufficient
3. Very lengthy questions (more than 40%)
I don't know how many people have cleared the exam.
I am little suprised to see 2 things in exam: 1. Project Management 2. Agile Desktop
I am not sure from where people are getting the information regarding these two topics in PDN.
PEGA academy should revisit the exam pattern and also should provide valid material for exam.
If anyone of you know the right path to learn more, please suggest!
Don't know the proper channel to escalate on this!
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
Westpac Banking Corporation
Yes, its true and it seems some options are incorrect. In real time we are not following the same procedure as mentioned in certification.
For Ex: create element question steps and the material also doesn't contain the steps which are given in certification.
CIBC
Thanks Jayachandra for your inputs. I just sent out an email to support team and will update you once I get any positive response.
CSAA
Was there any response from the support team? Were you able to study and finish the exam ?
I'm sorry to hear that. I have moved your post to the Pega Academy community where you will find more relevant discussions. I did happen to see this discussion though, please browse through the replies (I'd like to add special emphasis to the response from one of SMEs, Jeff Badger as we truly believe that suggestion could help you clear the certification) : Certified Robotic System Architect (CRSA) 8.0 Certification Exam now available
I also believe that you can email your feedback to SelfStudySupport@pega.com
CIBC
Hi Lochan,
I verified all the posts before posting this query. I don't see any sort of justification for the questions which I asked for.
Anyhow, I am going to drop an email SelfStudySupport@pega.com as you suggested.
I would recommend, support team has to do the survey who ever appeared for the exam so far. Based on this survey, I am sure they are going to get more clarity on this.
Thanks for your response
HCL Technologies Limited
Agile Desktop we can refer from
https://help.roboticautomation.pega.com/71/Agile_Desktop/Agile_Desktop_Overview.htm
https://docs.pega.com/pega-robotic-automation-agile-desktop-implementation-guide
"Visualizing Automations with an Agile Mindset" course in PDN helps to get more information on Agile
Mathumitha
CSAA
I'm planning to give this exam in next 20 days. Just wanted to understand if I need to learn any other material other than the certification course? Kindly let me know. And also thanks for sharing your experience. I was under an assumption that studying the course CRSA course would be good enough.
Srikanth
https://academy.pega.com/library/80/certified-robotics-system-architect
"Approximately 70% of the questions are based on course content; 30% of the questions are based on field experience."
This is wrong and this is probably the other way round.
It cannot harm to have a look at this: https://academy.pega.com/library/72/pega-robotic-automation-advanced-topics
I am not going to tell you what questions you will have but doing the course (multiple times) + doing the webinars (advance topics) will not suffice to get any close to the 70%.
Many answers are only available from the Robotics help and nowhere on Pega Academy.
Damien
Hi Srikanth,
There something very fishy with this Pega Certification. I have tried clearing it twice and both times I have been unsucceasful and received same percentage of marks. The questions are not present in either course or robotics online help. Also it seems that the test has incorrect answers stored in the backend so even if you mark the answers correctly it will be incorrect.
You can reach out for more information.
Abhishek
