CBA
Last activity: 25 Mar 2024 7:37 EDT
CDH Infinity 23 : Batch outbound run's produces no results
Hello Team, We are doing a simple POC with CDH infinity -23, I am facing couple of issues, though of seeking the advice. Issue #1 : Batch run scheduled from NBA-D is not writing the results into output table. Analysis: when I run the Trigger_NBA_TopLevel NBA strategy in the unit testing mode, it produces the offers, I need to debug where it it dropping. 1) I tried to run a simple Dataflow Run with the Group level Trigger Strategy, did not produce the results so I have changed the Strategy as such it should pass through the results i.e. removed eligibility Strategy + NBAStrategyFramework still no results, does this means the GOS is cached the Strategy content and all my changes are not reflected?
2) For some reason the Proposition Filer rule does not show all the Actions available under a give group, but corresponding Decision Data rule have both the Action rules instances.
Tried Simulation testing to understand where the Actions are dropped off, no luck. Thanks, Ravi
