Case Sensitive Filtering in Repeating Grid Layouts
The filtering functionality in repeating grids are case insensitive.
When report definitions are set as the source, I can see that the UPPER() function is added to the sql queries.
When data pages are set as the source, the results are case insensitive as well. I assume there is similar logic that converts the results and filtering criteria.
Is there a way to have case sensitive filtering? I cannot find an "ignore case" setting anywhere in repeating grid layouts.
***Moderator Edit-Vidyaranjan: Updated FDBK ID***
