Euroclear
BE
Last activity: 28 Jul 2016 11:14 EDT
Can't see the login screen when using Oracle virtual box manager
I installed virtualbox and started Pega the application 'LSA on 7.1.9'.I was expecting to see the login screen but i see some irrelevant black screen.Could you please help.
Hello Harish,
Can you try below solution(which had worked for me)?
Solution: Change network settings(to Bridged Adapter) as per below screenshot. Also, find it attached.
Also, try logging with below credentials on the VM(Although, this is not required to do)
Username : architect
Pwd: password
In the command prompt, type ifconfig and press enter
you need to go to http:// Proprietary information hidden:8080/prweb in your browser.
Euroclear
BE
This dint work , shows me page not available
1. Did you install the Bonjour Service as described in the VM Quick Start Guide ? If not please do.
2. Check if the Host Only Adapter is configured in Virtual Box and the same is used in the VM.
3. Access the environment using http://prpc.local:<port> or http://<starting IP in the Host Only Adaptor Range>:<port>. Try port 8080 or 9080.
Euroclear
BE
This is not Bonjour service .It recommended to download Oracle virtual box and use the LSA on 7.1.9.vbox file.
I did all zll the setup as in the documentation on the first chapter of CLSA part 1 tutorials.But when i start running the application i see a blank screen.
Please advice from where am i supposed to get the login info ( http://prpc.local:<port>)
Hello Harish,
Pwd: password
Updated: 7 Jul 2016 9:23 EDT
Hi Harish,
Is this a question related to Pega Academy course on LSA? If so, please raise you query with the Pega Academy team by writing an email to [email protected]
Hope this information helps!
Lochan | Online Community Moderator | Pegasystems Inc.
Euroclear
BE
thank you will do so
