Serendebyte
Last activity: 23 May 2017 9:36 EDT
Can we invoke an automation from pega 7.2.1 with OpenSpan 7 version
I have done an automation in OpenSpan 7 version which is invoked from flow action of pega 7.2.1. When I run the case, it showing an error stating "Unable to invoke robotic automation from this screen. The automation service is either unavailable or this system is not authorized to execute automations.". I have attached the errors.
Please Help!
***Updated by moderator: Lochan to move from Pega Academy to PSC; added topic categories***
Likes (1)
HIMA VARUN DASINENI -
OpenSpan 7.0 and 7.1 do not have integrated support with Pega 7.2.1. Only version 8.0.1012 and higher support Pega 7.2.1 integration. These errors are most likely occurring because Pega 7.2.1 cannot find Runtime.
Vishal,
Vegam is correct. Only versions of 8.0 and higher support the RDA and RPA features. You will need to automate the Pega 7 system using the traditional interrogation and automation design method for versions of OpenSpan below 8.0.
Serendebyte
Thanks for your valuable information! @Vegam & Thomz.
EY
Hi Thomz,
I am also facing this similar issue.
- Unable to invoke robotic automation from this screen. The automation service is either unavailable or this system is not authorized to execute automations. You have the option of either quitting or continuing with your work flow.
But i am using pega 7.2.2 and open span 8.0.1016.0
My system requirements are correct.
Pega Configuration:
I have set robotic run time as DSS localruntime.pega.com:9443
my Access group is having PegaRULES:PegaAPI role but my pega URL is not SSL. It is HTTP.
Studio Configuration:
Runtimeconfig.XML - I have done below settings
1. Added my domain and ipaddress under robotics section.
Do i need to configure any other settings?
Please help.
EPAM Systems
Hey,
Have you able to resolve this issue ?
Lalit
Unisys Global Services India
Hi
I am also facing exactly same issue. Were you able to fix this issue?
Note : I am using Http and not Https.
Akshatha
Hey Lalit,
Here are a few things that you can do to further your investigation of this issue:
- There is a property in the robotics section of the runtimeconfig.xml, it is called, allowedOrigins. Try setting the value to "*" and see if it works with that value.
- Make sure that the LocalApiService in the Robotics section is enabled to true.
- Make sure there are no typos that you entering into the RuntimeConfig.xml
- Make sure you are using the Robotic activity and not the regular activity.
- Confirm that Runtime is running on the machine either Studio Debugger or Standalone Runtime will work.
- Make sure you have the PegaAPI access Role.
- Try re-installing Studio/Runtime to see if that resolves the issue.
Capgemini Pvt Ltd
Hi
What is difference between Open Span 7.2 and 8.0.
please send me all differences.
and
What is procedure to download the OpenSpan 8.0 Software from pega site??
Santosh Bhandari
This comment has been branched out as a new node and the new thread can be followed here
Hi Santosh,
Since this question has been Answered and yours is a new one, we have created a new post for you - Difference between Open Span 7.2 and 8.0
Please continue the discussion over the new post.
Thank you,
