Can we have different/seperate JDBC data sources for RULES and DATA (Work) schemas
As per documentation, PEGA has started supporting split schema model in PRPC7.1. Even though, it supports two schemas in split schema model, application uses only one JDBC data source to access objects in both the schemas at run time. Is it possible to make PRPC application to use two JDBC data sources (one for Rules and One for DATA) instead of one? If so, could you please share some documentation?
Please find below our application server and DB details.
Application Server: Weblogic 12.1.3
Database: Oracle 11.2.0.3.0
