Zad
TR
Posted: Feb 13, 2023
Last activity: Mar 7, 2023
Last activity: 7 Mar 2023 8:15 EST
Can i add column in this page
I want to add a column on this page from one of the fields in the task how can I do it?
@georgeh16741365 Open the section, there you can add available columns in the source.
@georgeh16741365 Its a Worklist. This would be in a section and in that there would be a table. click on column where you want to add the new column, there on top we would get the corresponding option to add the column before or after the column selected.
Hopes helps!
UC
@Chandan U I can't find an option to add a column with one of the fields in the case itself
Hi @georgeh16741365,
I think in your requirement data is fetching from deport definition so open that report and you can add one column in that report.
Thanks.
You can track the section using LIVE UI, and check the source of the table whether it is a Data Page or Report Definition. You can add a column in the table layout and same property to be mapped in the Data page source or Report definition.
