CallScript component help
Why exactly we needed this CallScript component in Pega Robotics?
We can use the script component to dynamically send the values to variables used inside the script/input parameters.
How does script and callscript differ?
Can we write C# syntax code in Callscript editor?if yes, how can we validate the script?if No - the string with dynamic parameters(tokens) can even be acheived with stringutils?
I am not able to see the Callscript Popup using show method. I am getting error "Invalid URI: The format of the URI could not be determined."
How does this Call script - Device work please share an example.
Please help.
Thank you!
