Calling stored proc that accepts table type parameters
How to call a stored proc in Pega that accepts table type input parameter?
@DevendraP17332832 To call a stored procedure in Pega that accepts a table-type input parameter, you need to use a Connect-SQL or Connect-Procedure rule. First, create a corresponding Page List property in Pega that represents the table structure. Then, define a class and property structure that matches the SQL table type. In the Connect-SQL or Connect-Procedure rule, use a parameterized query and pass the table-type parameter using Database Save or Data Transform logic. Ensure the JDBC driver and database support structured types (like Oracle's TABLE or SQL Server's UDT). You may also need to use a Java step in an activity to build and map the parameter properly with java.sql.Struct or ArrayDescriptor, depending on your DB. Finally, test the procedure by tracing the execution and validating the table-type input is correctly passed
