Automatic Field Population in Case Management Systems
Hi everyone,
Whenever I create a case, I notice that the values for the priority, status, created, and updated fields are automatically populated. I did not set these values myself. Can anyone explain where these values are coming from?
Hi @suresh P
When creating a case type in Pega, a pyDefault data transform is automatically generated. By default, the "Super class data transform" checkbox is enabled in this data transform. This configuration ensures that Pega checks the inherited parent classes up to the base class, applying the appropriate data transformations from those classes. Consequently, fields such as priority, status, created, and updated are automatically populated based on these inherited data transforms
for Priority field: "pyUrgencyWork"
Status field: "pyStatusWork"
Created field: "pxCreateDateTime"
Updated field: "pxUpdateDateTime"
