Ridge Business Solutions LLC
Last activity: 10 Apr 2022 23:18 EDT
Approaches for building Workflow solution in Pega as a Headless? (UI in third party frameworks, and processes in Pega)
I would like to understand the approaches for building the workflow solutions in Pega as a headless.
In short, the requirement is not to use Pega for the UI component and leverage Pega only for all of it’s Workflow and rule engine capabilities.
The key point to observe here is we are not building a BRE solution.
We are building a typical workflow solution which involves all of the features like processes, parent-child relationships, stages, case management, worklists, work baskets, Workgroups, SLA’s.
I have the below questions when we have to separate UI from Pega –
- Can we still make use of work objects, build flows with assignments, link flow actions to assignments?
- If Yes, how do we link UI or screens built in the third party frameworks with the Process flows and assignments in Pega? If we do not build flow rules within Pega, then how do we maintain the state / stages of the objects and how can we achieve the workflow functionalities? At what level the micro-services need to be build?(work object level or assignment level or flow action level)?
- Where does the sequence logic of displaying the appropriate UI screens in the third party UI frameworks reside? For instance, Pega displays the appropriate flow action with the highest likelihood at the assignment.
- Can the Pega authorization component be exposed with this micro services approach or should the authorization be completely outside of Pega?
Finally, has any one implemented or aware of such implementation?
