Apply filter using greater than( >) and with column names having space in between like "Amount Paid"
We are facing issue in applying filter on lookup table where Column Name has space in between and also when we want to use greater than option with numeric columns like "Amount paid"
kindly provide approach for the same, can we use tableView or any other option is available
Use stringutils to trim the whitespace, then convert it to an int before using the comparison.
