Application up in CNJ node but not in TPC
Hi
I deployed my application in cnj and tpc node and both pointing to same DB. Application is failing in tpc node but getting deployed fine in cnj node. From the log the only difference I see is in "PegaRULES Bootstrap Configuration" I see ASM Version: -825689265 for cnj node but no such detail for tpc node. Is this the reason for failure? What is ASM Version: -825689265 ??
Attaching both the logs. Pls assist.
