Agile Studio Import Slowness Question
I installed a Pega Platform 8.1 instance a few months back with Agile Studio and while doing the import for Agile studio it took a deathly amount of hours to finish. This instance was configured with Tomcat Apache 8 & Sql Server DB. Recently one of my colleagues performed the same import for another Pega 8.3 instance which utilizes Tomcat Apache 8 & Oracle DB. In the catalina logs he was able to locate some errors which pointed to an attribute/value named MaxOpenCursors which was set to around 60 but once he ran the following command: ALTER SYSTEM SET open_cursors = 800 SCOPE=BOTH; He noticed the import sped up intensely. So I did some digging in the logs from when I initially created the 8.1 instance but found no such attribute/value or any errors even remotely close.
I am wondering if anyone has any idea on if there is a similar attribute/value which can be configured to speed up the Agile studio import for Sql Server? Or anything that can be configured to accelerate the import process?
Thank you.
