  Wells Fargo
Last activity: 25 Sep 2019 8:23 EDT
Agile Studio 8.2 upgrade issue
We upgraded to the Agile 8.2 from 7.4 on PEGA 8.2.3.
The upgrade installed fine. however, part of the upgrade will need to run "ConvertAllWOsToStageBased" for all these classes, and the User story upgrade took forever and we don't have much user stories in the system.
Each batch coverts 1200 user stories.
AgileStudioSysAdmin - Started Utility ConvertAllWOsToStageBased at : 20190907T014553.860 GMT
2019-09-06 18:45:53,860 [ttp-nio-8080-exec-28] [ STANDARD] [ ] [ AgileStudio:08.02] (Based.PegaProjMgmt_Work.Action) INFO localhost| Proprietary information hidden AgileStudioSysAdmin - Following parameters were passed :: ClassToBeConverted : PegaProjMgmt-Work-UserStory
We are up to 80 some batches now, so it's almost over 100000 user stories. I don' t think we have that many.
Is ConvertAllWOsToStageBased mandatory? Can we keep the existing items running on old process and new ones run in stage based?
Thanks.
  Louis Dreyfus Company
FR
Terminate your operator and go to the next class def, we had this issue too on the following type :
PegaProjMgmt-Work-Feature
Even with that Agile studio should work well.
I opened an SR couple weeks ago on this subject : SR-D35556
Hi Everyone,
The issue will occur when there is a empty input while running the activity ConvertAllWOsToStageBased.
Please provide the valid inputs to all the parameters to the ConvertAllWOsToStageBased activity and try the scenario.
Please let me know if you have any questions.
FR
Hello Mahesh,
The documentation state the following :
1. Log on as an operator with access to Dev Studio.
2. Open activity PegaProjMgmt-Work.ConvertAllWOsToStageBased.
3. Click Actions  > Run.
4. On the execution modal, leave the default values unchanged, and then click Run.
5.To convert all work items to stage based pass the ClassToBeConverted parameter value in the following order and run the activity sequentially.
It's what we are doing and it's with these instructions that we have issue to run the activity.
There is no guidance on how to fill other parameter nor an explanation why it work for almost all class except two.
  Wells Fargo
The documentation only states to enter the list of the class for the conversion:
The user story class basically falls into the a loop that creating unlimited amount of the batch work until we restart the instance.
In the document it was mentioned as below.
Enabling stages for stories
1. Log on as an operator with access to Designer Studio.
4. On the execution modal, leave the default values unchanged(PegaProjMgmt-Work-UserStory-Epic), and then click Run.
FR
You are missing the fifth point :
5.To convert all work items to stage based pass the ClassToBeConverted parameter value in the following order and run the activity sequentially :
•PegaProjMgmt-Work-Product
•PegaProjMgmt-Work-Product-Version
•PegaProjMgmt-Work-Goal
•PegaProjMgmt-Work-Feature
•PegaProjMgmt-Work-Backlog
•PegaProjMgmt-Work-Project
•PegaProjMgmt-Work-Sprint
•PegaProjMgmt-Work-UserStory
•PegaProjMgmt-Work-UserStory-Epic
•PegaProjMgmt-Work-Task
•PegaProjMgmt-Work-Bug
•PegaProjMgmt-Work-Issue
•PegaProjMgmt-Work-Task-Feedback
Please share the results after running the report definition GetWorkItemsForNewStageConversion.
Please share the results after running the report definition GetWorkItemsForNewStageConversion by passing the userstory class "PegaProjMgmt-Work-UserStory".
  Wells Fargo
What result that I should look for? There are a lot of tasks/user stories in the list.
