After importing log4J HFIX on 7.3,7.3.1 & 7.4 Pega Application went down
We have imported latest log4j hfix on 7.3 , 7.3.1 & 7.4, After restart pega engine is not coming up. Failed due to hazel cast errors.
Below are the Hfix installed in to the resp. pega system. { Our apps are still on 7.3 , 731 & 7.4}
7.3 |
DL-9012_HF-56098.zip |
7.3.1 |
DL-8670_HF-55820.zip |
7.4 |
DL-9013_HF-56099.zip |
7.3 |
7.3.1 |
7.4 |
2022-01-05 01:54:59,476 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: ivapp1186238.devin3.ms.com
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:404) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:2061) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:673) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:172) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:145) ~[prprivate.jar:?]
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:326) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:221) ~[prwebj2ee.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_192]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_192]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_192]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_192]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) ~[prbootstrap-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) ~[prbootstrap-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4699) ~[catalina.jar:8.5.49]
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5165) ~[catalina.jar:8.5.49]
at com.ms.webeng.tomcat.MorganStanleyContext.startInternal(MorganStanleyContext.java:204) ~[webinfra.tomcat-libs.jar:?]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) ~[catalina.jar:8.5.49]
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:743) ~[catalina.jar:8.5.49]
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:719) ~[catalina.jar:8.5.49]
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705) ~[catalina.jar:8.5.49]
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:614) ~[catalina.jar:8.5.49]
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1823) ~[catalina.jar:8.5.49]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_192]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_192]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_192]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_192]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_192]
Caused by: java.lang.NoSuchFieldError: config
at com.hazelcast.instance.EnterpriseNodeExtension.beforeStart(EnterpriseNodeExtension.java:150) ~[hazelcast-enterprise-3.10_1.jar:3.8]
at com.hazelcast.instance.Node.<init>(Node.java:199) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.instance.HazelcastInstanceImpl.createNode(HazelcastInstanceImpl.java:163) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.instance.HazelcastInstanceImpl.<init>(HazelcastInstanceImpl.java:130) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.instance.HazelcastInstanceFactory.constructHazelcastInstance(HazelcastInstanceFactory.java:218) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.instance.HazelcastInstanceFactory.newHazelcastInstance(HazelcastInstanceFactory.java:176) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.instance.HazelcastInstanceFactory.newHazelcastInstance(HazelcastInstanceFactory.java:126) ~[hazelcast-3.8_1.jar:3.8]
at com.hazelcast.core.Hazelcast.newHazelcastInstance(Hazelcast.java:58) ~[hazelcast-3.8_1.jar:3.8]
at com.pega.platform.cluster.internal.HazelcastClusterProvider.initialize(HazelcastClusterProvider.java:109) ~[cluster-impl.jar:?]
at com.pega.platform.cluster.internal.AbstractClusterProvider.start(AbstractClusterProvider.java:111) ~[cluster-impl.jar:?]
at com.pega.platform.cluster.management.internal.DefaultClusterManager.start(DefaultClusterManager.java:114) ~[cluster-impl.jar:?]
at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.initialize(PRClusterHazelcastImpl.java:527) ~[prcluster.jar:?]
at com.pega.pegarules.cluster.internal.PRClusterImpl.getInstance(PRClusterImpl.java:272) ~[prcluster.jar:?]
at com.pega.pegarules.cluster.internal.PRClusterProviderImpl.getInstance(PRClusterProviderImpl.java:98) ~[prcluster.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.joinCluster(PRNodeImpl.java:2715) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:937) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:379) ~[prprivate.jar:?]
... 29 more
2022-01-05 01:54:59,485 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES initialization failed. Server: ivapp1186238.devin3.ms.com
2022-01-05 01:54:59,660 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) ERROR - Enterprise tier failed to initialize properly, PegaRULES not available
2022-01-05 01:54:59,673 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Initializing push engine...
2022-01-05 01:55:03,604 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (tmosphere.AtmospherePushEngine) INFO - Async support implementation used by framework: org.atmosphere.container.JSR356AsyncSupport
2022-01-05 01:55:03,868 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (.PushSubscriptionCleanerDaemon) INFO - Push Subscription Cleaner Daemon initialized in web-tier.
2022-01-05 01:55:03,901 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (senceSessionStateTrackerDaemon) INFO - Presence Session State Tracker Daemon initialized in web-tier.
2022-01-05 01:55:03,901 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Push engine initialization finished!
2022-01-05 01:55:03,901 [186238.devin3.ms.com] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complete
***Edited by Moderator Marissa to add Support Case Details***
