LOG4j Vulnerability
Need to have the latest LOG4J hotfix for PEGA 8.5.1
Could you please check the Support Doc on Pega Security Advisory - Pega Platform Apache Log4j 2.17.1 Vulnerability Hotfixes ?
Please, could you also read through the Support Doc Pega Security Advisory - Apache Log4j 2.17 Vulnerability Hotfixes?
Dear @PoojaGadige
The below ZIP file contents sent by PEGA.
Should we apply all the below JAR's of the one related to PEGA 8.5.1 which is HFIX-82254
@amry8717 Hi , you will get reply from pega team anyways , my 2 cents is you should not unzip the hotfix folder and apply the jars independently, directly upload the hfix zip file from Pega hotfix wizard in devstudio , may be now it will be in Admin studio if you have access and continue the installation. Hfix wizard is self explanatory guided user navigation to install hotfixes.
@amry8717 Hi, Greetings. You need to use Hotfix Manager to install the DL file sent by Pega, this will install all dependent HFixes and supersede automatically any HFixes.
Bharat
Support Doc
Support Doc
Support Doc
Support Doc
