Anthem
Last activity: 19 Jan 2019 9:28 EST
AES server recurring pega exceptions in the logs.
Hi Andy/Jim,
Below mentioned errors has been observed very frequently in the pega logs @ AES.
Please suggest.
1) 2019-01-16 00:01:02,369 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ AES:07.30] ( internal.mgmt.Executable) ERROR Rule-Connect-SOAP.PegaAES-Data-RSSnapshot.GetRuleSetSnapshot - Exception
com.pega.pegarules.pub.services.ConnectorException: Service URL '[unable to determine]' value is invalid
2) 2019-01-16 11:56:12,820 [sse-nio-8443-exec-54] [ STANDARD] [ ] [ AES:07.30] (nvoke.Rule_Connect_REST.Action) ERROR va10n40604.wellpoint.com|30.239.117.148|Rule-Connect-REST.Pega-Int-PDN-Rss.pyRSSConnectService amar - com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: java.lang.RuntimeException: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
3) 2019-01-16 11:54:26,131 [sse-nio-8443-exec-16] [ ] [ ] [ ] ( web.impl.WebStandardImpl) ERROR - 30.135.161.179: Problem retrieving input data:
java.io.IOException: Invalid chunk header
4) 2019-01-16 11:59:01,741 [sse-nio-8443-exec-24] [TABTHREAD1] [ ] [ AES:07.30] (ler.FilesystemCompilationSaver) ERROR va10n40604.wellpoint.com|10.103.194.155 pydi - Problem saving Java source file to filesystem
Hi Andy/Jim,
Please suggest.
java.io.IOException: No space left on device
5) 2019-01-16 11:56:12,784 [sse-nio-8443-exec-54] [ STANDARD] [ ] [ AES:07.30] ( connect.rest.RESTConnector) ERROR va10n40604.wellpoint.com|30.239.117.148|Rule-Connect-REST.Pega-Int-PDN-Rss.pyRSSConnectService amar - HTTP connect execution failure: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
6) 2019-01-16 11:56:12,790 [sse-nio-8443-exec-54] [ STANDARD] [ ] [ AES:07.30] ( connect.rest.RESTConnector) ERROR va10n40604.wellpoint.com|30.239.117.148|Rule-Connect-REST.Pega-Int-PDN-Rss.pyRSSConnectService amar - Rule-Connect-REST: http://pdn.pega.com/rss/designerstudio - Caught unhandled exception: java.lang.RuntimeException: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty - javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
