Verizon
Last activity: 7 Feb 2018 8:02 EST
Actual query being executed after bind variables are replaced with values
I would like to understand how the bind variables are replaced with actual values when Pega passes the query to the database.
Let me explain the scenario. We have a property (xyz) which is defined as Integer Data Type in Pega and is mapped to a column (xyz)in DB of VARCHAR2 data type. We also have a database index created on this column.
We have a report definition which when executed results in the following query: select count(pyID) from schema.tablename where xyz = ?
where ? is the value passed. Say the value being passed is 1234.
When this query is executed, will the bind variable be replaced like
(1). select count(pyID) from schema.tablename where xyz = '1234'
or
(2). select count(pyID) from schema.tablename where xyz = 1234
In (1) the database index would be used. In (2) it will not be used.
In Production, this query randomly(not often) pops up in our AWR report and our DBA says that it is because Integer value is passed to a varchar column and Oracle sometimes treats it as Integer and doesn't apply the index.
Pega Version : 7.2
Database : Oracle 12c
