Nationwide Building Society
Last activity: 13 Dec 2024 12:00 EST
22.1 robot not loading dlls
22.1 robot requires 3 DLL's which are manually installed in 22.1 robot studio installation directory as part of robot dev and build (C:\Program Files (x86)\Pegasystems\Pega Robot Studio v22\)
However when robot is built and deployed the package is not created in the Appdata/Local/pegsystems folder as per 19.1 build. It was in this local directory that the dll's were created which the 19.1 runtime package then referenced
When running the package on a 22.1 runtime device the robot functionality which needs to consume the dll's does not work. The only way we can get the robot to work is to manually install the dll's in the robot runtime installation diectory
Obviously this creates issues for us as we can't manually install the dll's on 1000+ bot devices in the business
Is there a development/build solution to this problem which doesn't require and additional component to the 22.1 runtime package to install the dll's after runtime software installation
