Bits In Glass
Bits In Glass
Bits In Glass
Posted: 2 days 22 hours ago
Last activity: 2 days 1 hour ago
Last activity: 12 Jan 2026 23:36 EST
Pega Archival is showing exception in the logs - Illegal characters detected in the path "pegacloudfilestorage:/archive"
com.pega.platform.integrationengine.repository.RepositoryException: There was an issue creating the folder. at com.pega.platform.integrationengine.repository.internal.RepositoryManagerImpl.createFolder(RepositoryManagerImpl.java:442) ~[integration-engine.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.FileUtils.createFolderOnSecondaryStorage(FileUtils.java:126) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.FileUtils.buildFolderStructureOnSecondaryStorage(FileUtils.java:98) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.transferFilesToSecondaryStorage(CaseArchivalStrategy.java:285) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.doCopy(CaseArchivalStrategy.java:215) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.performCopy(CaseArchivalStrategy.java:123) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.doArchive(CaseArchivalStrategy.java:107) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.DataCopierImpl.doCopy(DataCopierImpl.java:55) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.archivebroker.internal.DataCopierTask.runService(DataCopierTask.java:47) ~[datastoreexecutor.jar:?] at com.pegarules.generated.activity.ra_action_pzdatabrokerservice
Show More
com.pega.platform.integrationengine.repository.RepositoryException: There was an issue creating the folder. at com.pega.platform.integrationengine.repository.internal.RepositoryManagerImpl.createFolder(RepositoryManagerImpl.java:442) ~[integration-engine.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.FileUtils.createFolderOnSecondaryStorage(FileUtils.java:126) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.FileUtils.buildFolderStructureOnSecondaryStorage(FileUtils.java:98) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.transferFilesToSecondaryStorage(CaseArchivalStrategy.java:285) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.doCopy(CaseArchivalStrategy.java:215) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.performCopy(CaseArchivalStrategy.java:123) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.CaseArchivalStrategy.doArchive(CaseArchivalStrategy.java:107) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.copier.internal.DataCopierImpl.doCopy(DataCopierImpl.java:55) ~[datastoreexecutor.jar:?] at com.pega.platform.datastoreexecutor.archivebroker.internal.DataCopierTask.runService(DataCopierTask.java:47) ~[datastoreexecutor.jar:?] at com.pegarules.generated.activity.ra_action_pzdatabrokerservice_2309def10ef890a486d921972ede57d0.step1_circum0(ra_action_pzdatabrokerservice_2309def10ef890a486d921972ede57d0.java:167) ~[?:?] at com.pegarules.generated.activity.ra_action_pzdatabrokerservice_2309def10ef890a486d921972ede57d0.perform(ra_action_pzdatabrokerservice_2309def10ef890a486d921972ede57d0.java:76) ~[?:?] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2927) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:653) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:580) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:525) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:308) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:364) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1183) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1379) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1122) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1003) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:839) ~[prprivate-session.jar:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?] at java.lang.Thread.run(Thread.java:840) [?:?] Caused by: java.lang.IllegalArgumentException: Illegal characters detected in the path "pegacloudfilestorage:/archive". You may not use the following characters: [", ?, *, <, >, |, :] at com.pega.pegarules.priv.storage.StorageUtils.normalizeRelativePath(StorageUtils.java:267) ~[prpublic.jar:?] at com.pega.pegarules.priv.storage.StorageUtils.normalizeRelativePath(StorageUtils.java:217) ~[prpublic.jar:?] at com.pega.pegarules.storage.FileStorageManager.getFile(FileStorageManager.java:873) ~[prprivcommon.jar:?] at com.pega.platform.integrationengine.repository.internal.RepositoryManagerImpl.createFolder(RepositoryManagerImpl.java:432) ~[integration-engine.jar:?]
Show Less
