Learn how to know to which environment a specific PDC is linked.
Knowledge of name of impacted environment on PDC is crucial for monitoring your applications at run-time and gathering performance, quality rich, and diagnostic data for Pega Platform components.
Sometimes the name of the environment does not match with the system available on PDC.
In order to know the environment, log in to PDC of system you want to check and perform the following steps:
- Navigate to System Resources > Nodes
- Click any node
- Navigate to Configuration Setting Info tab
- Filter Configuration name tab by:
Pega-rules/deployment/deploymentname - Verify the value of this configuration name to know the name of the respective environment.
Note - It's not guaranteed that the PDC name will be the same as the actual environment name.
